Bodoque
Apr 15, 2025Aspirant
How to find BE9300 Tri band wifi router IMEI?
I'm trying to find the IMEI number that's associated with my router I don't see it on the router itself, on the app or when I log in to Netgear as an admin. Does anybody know where to find the IMEI if...
Bodoque
So if I want to check if the BE9300 router is compatible with Verizon business wifi you are saying I can't check if it's compatible since the router doesn't have an IMEI to input when prompted by Verizon to put one in?
Apr 15, 2025Guru - Experienced User
what actual device do you have? I don't know of any RS series that are sim card compatible (yet) but something could have been released.
