AlpineKid75
Mar 06, 2025Follower
how to replace a r7000p-100nas with a rs300
The RS 300 showed up and would like to know if there is a video on how to replace/remove the Netgear Nighthawk AC2300.
If there is no video, then can I get some help on what is the best way to get this accomplished.
I have 2 hardwired desktops, hardwired laptop, iPhones, iPads and an EPSON & HP ENVY Pro 6544 printers.
I am thinking that there is software to be removed from the computers.
Thank you
1 Reply
Would be nothing to remove from your computers, all that is needed would be to follow the setup instructions for the new router once you have powered OFF the old router and ISP Modem.
https://www.downloads.netgear.com/files/GDC/RS300/RS300_RS280_QSG_EN.pdf
Connect the new router to the ISP modem, then power back ON the ISP modem, then the new router and install the router using the Nighthawk mobile app on a phone or pad or use a ethernet connected PC and web browser to install the new router: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
