BILL1836
Sep 26, 2024Aspirant
I can not change the guest network key
I have gone to the router web site and tried to change the guest network PW.I can add characters to what is there but it will not save the new characters. Any ideas?
michaelkenward
Sep 26, 2024Guru - Experienced User
Once is usually enough:
Want to change PW in extender--BE9200 - NETGEAR Communities
Just another user with time on their hands.
- BILL1836Sep 26, 2024Aspirant
I have an extender and was on the route website but did not find a place to change the extenders PW. Can I do it there or have to go someplace else?
- michaelkenwardSep 26, 2024Guru - Experienced User
Which Netgear device is this? BE9200 is a model number that I recognise.
WIFI 7,BE9200-RS280S. UPS 606449-171310.I hope this helps.
