Wayne1938
Apr 26, 2025Guide
I Don't understand how the RS300 operates.
I have had the router for 3 days and have it set up and working, but I have some questions. At first, I couldn't connect to the 5G band. I changed the channel from auto to 153 and got that working. ...
- Apr 27, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Wayne1938
Apr 27, 2025Guide
I reset the router to the default setting,s then re-installed everything back in using the QR code and Nighthawk App.
Put in the same channel numbers and the problem I was having is gone and it's working great now.
Something got messed up the first time, what?? 🙄
Apr 27, 2025Guru - Experienced User
Enjoy. 📡
