netg007
Feb 24, 2026Aspirant
I got RS 180, Please help
I am having same issue. Tried so many configurations like disabling protection, acl, IGMP, etc but still nintendo not working properly. Connection says it is connected but when running test but it e...
netg007
Feb 25, 2026Aspirant
Thanks, tried AP mode, but that was acting up. Only Guest network worked. Other one no internet. speed I get around 300.
- StephenBFeb 26, 2026Guru - Experienced User
That is odd, and worth trying again.
Does the Nintendo work correctly when connected to the TMOG4AR wifi?
I am wondering why you are using the RS180, since the TMOG4AR is a reasonable dual-band WiFi 6 router.
