rhodan777
Dec 09, 2023Tutor
I need 220v power supply for RS700
I need 220v power supply for RS700. I purchased RS700 US version and since it has big dc power jack, it is hard to find something like this. any suggestion?
- Sep 11, 2024
Hello all,
Netgear Support provided me with these details about the replacement AC adapter power cord for my RS700 router:
Product Code: 332-11480-02
Product Accessory: PA,19V,3.16A,NJ,PIE,LRI found a replacement AC adapter power cord on Amazon Canada and on Amazon USA. It is from a brand called T-Power.
Search for this on the USA site "T POWER 19V Charger for Netgear Orbi 960 970 Series Quad-Band WiFi 6E 7 Network Mesh RS700S".
Search for this on the Canada site "T Power 19V Charger for Netgear Orbi 960 970 RS700S"
It is almost half the price on the USA site if you have a forwarding service.
Looks like we can even share links, enjoy:
michaelkenward
Dec 10, 2023Guru - Experienced User
rhodan777 wrote:
I purchased RS700 US version and since it has big dc power jack...
You mean the plug that goes from the adapter into the router?
Netgear does not sell replacement power adapters in most markets. Any generic transformer will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
The details you need should be on the old adapter, on a label on the device itself and in its manual.
You can find suitable adapters in all the usual places. Some will even list compatibility with different Netgear hardware.
Some generic adapters come with a set of tips that will fit a range of different devices.
Generic adapter
Does you US adapter have the specifications on it? The manual for the RS700 says that the adapter for North America is "100-240V, 50/60 Hz input".
Many are 120/240 volt and you can just use an appropriate adapter to plug it into the wall socket.
