rhodan777
Dec 09, 2023Tutor
I need 220v power supply for RS700
I need 220v power supply for RS700. I purchased RS700 US version and since it has big dc power jack, it is hard to find something like this. any suggestion?
- Sep 11, 2024
Hello all,
Netgear Support provided me with these details about the replacement AC adapter power cord for my RS700 router:
Product Code: 332-11480-02
Product Accessory: PA,19V,3.16A,NJ,PIE,LRI found a replacement AC adapter power cord on Amazon Canada and on Amazon USA. It is from a brand called T-Power.
Search for this on the USA site "T POWER 19V Charger for Netgear Orbi 960 970 Series Quad-Band WiFi 6E 7 Network Mesh RS700S".
Search for this on the Canada site "T Power 19V Charger for Netgear Orbi 960 970 RS700S"
It is almost half the price on the USA site if you have a forwarding service.
Looks like we can even share links, enjoy:
jessejames87
Dec 14, 2023Apprentice
Was asked to post the picture of the power plug end and the socket on router so here we are... no pin in the middle of the plug.
- schumakuDec 14, 2023Guru - Experienced User
Thank you jessejames87 !
Yes - depending on the wording, to some users the inner connector (where the small additional contact for the additional always-on power for modems and WoL is located) does look like a large center pin (reversed) to the common DC barrel plugs. This is where the confusion is coming from - leaving alone I have not seen these on standardized power supplies yet - what can make it difficult to locate third party alternate power supplies.
