rhodan777
Dec 09, 2023Tutor
I need 220v power supply for RS700
I need 220v power supply for RS700. I purchased RS700 US version and since it has big dc power jack, it is hard to find something like this. any suggestion?
- Sep 11, 2024
Hello all,
Netgear Support provided me with these details about the replacement AC adapter power cord for my RS700 router:
Product Code: 332-11480-02
Product Accessory: PA,19V,3.16A,NJ,PIE,LRI found a replacement AC adapter power cord on Amazon Canada and on Amazon USA. It is from a brand called T-Power.
Search for this on the USA site "T POWER 19V Charger for Netgear Orbi 960 970 Series Quad-Band WiFi 6E 7 Network Mesh RS700S".
Search for this on the Canada site "T Power 19V Charger for Netgear Orbi 960 970 RS700S"
It is almost half the price on the USA site if you have a forwarding service.
Looks like we can even share links, enjoy:
jessejames87
Dec 14, 2023Apprentice
Was asked to post the picture of the power plug end and the socket on router so here we are... no pin in the middle of the plug.
- FURRYe38Dec 14, 2023Guru - Experienced User
Thanks jessejames87 for posting that. Confirms it's the larger center pin as I suspected. I see the pin is (+) as well. Glad that's still standard.
So maybe possible for the RAXE500 PS that could be compatible. Can you post a picture of the PS label from the RS700?
- jessejames87Dec 14, 2023Apprentice
not the best photo but legible.
- schumakuDec 14, 2023Guru - Experienced User
All newer models like the RS700, WAXE500, WAXE450, ... share the same 19V/60W power supply DC connectors. The same power supplies can be used on -all- 19V DC units like the R9000 with the (fully standard compliant) APC models, the small inner 0.6mm pin is is not required. This variant is much easier to be found in the free market then want I think is the proprietary modded one.
