bronzelincolns
May 06, 2025Aspirant
I only get half speed for RS200 router
My phones and my tablet get full speed on my wifi which is rated from the ISP for 1.1G down and 300M up. My PC wired with CAT8 cable has only gotten as high as 650 from Ookla speed test and 570 with ...
- May 09, 2025
SOLVED!!
I uninstalled several apps and went to do another speedtest and BAM! full speed upstream and downstream! Don't know which app was causing the issue but I read on the internet about something called "Microsoft teams client" or something like that. I saw that in the list of apps and uninstalled it. I'm now getting the speed I paid for!
I also ran this script in cmd: "netsh int tcp set global autotuninglevel=normal". I suppose I can't pinpoint what fixed the issue, I'm just glad everything is good now.
bronzelincolns
May 08, 2025Aspirant
I just did an upgrade to the RS700s and have a TPlink 10Gig PCIe network adapter. Same result. Hard capped at around 570 on Xfinity speedtest and 650 on Ookla speedtest with higher speed on my mobile devices.
May 08, 2025Guru - Experienced User
when 2 different devices perform the same, it makes me suspicious of what you're testing with. Especially since wifi hits faster speeds. got an older gigabit device sitting around you can test with versus the 10g adapter?
