bronzelincolns
May 06, 2025Aspirant
I only get half speed for RS200 router
My phones and my tablet get full speed on my wifi which is rated from the ISP for 1.1G down and 300M up. My PC wired with CAT8 cable has only gotten as high as 650 from Ookla speed test and 570 with ...
- May 09, 2025
SOLVED!!
I uninstalled several apps and went to do another speedtest and BAM! full speed upstream and downstream! Don't know which app was causing the issue but I read on the internet about something called "Microsoft teams client" or something like that. I saw that in the list of apps and uninstalled it. I'm now getting the speed I paid for!
I also ran this script in cmd: "netsh int tcp set global autotuninglevel=normal". I suppose I can't pinpoint what fixed the issue, I'm just glad everything is good now.
bronzelincolns
May 09, 2025Aspirant
SOLVED!!
May 09, 2025Guru - Experienced User
Glad you got it fixed! And that it was a simple issue related to the PC. I'd make a backup of that setup point on the PC as they're great at "updating drivers/apps" that can cause those issues to come back. I had a first gen 10g adapter that was a fight to keep running decent.
You might mark it solved so others know what fixed it and aren't still trying to fix it
