treefrog7
May 13, 2025Aspirant
I'm having the same problem on my RS300 with firmware V1.0.1.90
Were you able to solve this issue? I'm having the same problem on my RS300 with firmware V1.0.1.90.
treefrog7
May 14, 2025Aspirant
The issue only happens on wireless.
Channel configuration: Auto, 48, Auto (I changed the 5 GHz to 48 as a troubleshooting step; it didn't help)
Yes, Smart Connect is enabled.
No, I don't see Protection Engine
FWIW, I've had this issue on the regular network and the guest network.
I'll try a factory reset and report back.
May 14, 2025Guru - Experienced User
After the reset and setup from scratch, try setting manual channels 1 and 40.
- treefrog7May 14, 2025Aspirant
I've made the changes. It might take a few days to determine their effect. For whatever reason, the lag only happens when I'm in a live video call. Playing a recording of one works fine.
- FURRYe38May 15, 2025Guru - Experienced User
And you did a factory reset and setup from scratch?
Is SIP ALG enabled on the router? Under Advanced Tab/Setup/WAN Setup.
- treefrog7May 15, 2025Aspirant
I did a factory reset, setup from scratch, and changed the channels to 1 and 40.
The "Disable SIP ALG" setting is NOT checked.
