coter
Nov 16, 2024Aspirant
Im looking to get a netgear router need help.
Im looking at the NETGEAR Nighthawk BE9200 Wi-Fi 7 Tri-Band Router What is your opinion on this and how well does it work also im getting it at Costco for $270
1 Reply
Odd question. People turn up here with problems that need fixing. So you are likely to see that sort of stuff. When it comes to "how well does it work", it all depends on what you want to do.
Are you talking about the RS280 router?
Do you have any WiFi clients that can connect to 6 GHz WiFi 7? Do you have any Ethernet stuff that works at 2.5 Gbps?
To find something that fits in with your needs, start at the product pages.
Try plugging your needs into the filters there:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Just another user with time on their hands.
