PyroWolf89
Dec 21, 2024Aspirant
Inconsistent Speed Test with RS300 on WIFI, Good Hardline Speed, (Less then 20 feet dist.)
Router Firmware Version V1.0.1.60 So I have now been through 2 RS300's (which I bought for their 2 2.5GB ports, and am quite pleased with the performance of those ports), But I have this issu...
Dec 21, 2024Guru - Experienced User
What wireless devices are you speed testing with?
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
- PyroWolf89Dec 24, 2024Aspirant
Thank you for the reply.
I appreciate the through examples given, but I don't believe those principles apply here. I have tested the WIFI using my laptop (Intel AX201 Wi-Fi 6) and my Samsung S22+My Laptop isnt 6E, so I cannot use the 6Ghz band, but my phone is.
The first chart is the laptop speed over the last 5 days, as you can see it varies rather dramatically. But I cannot find "why" it dips like it does, and it isn't device specific (2nd photo, phone, showing same dip of speed) but if I run the test with the 6E moments later I get 650 Mbps, same location.
I feel like its being throttled specifically in the 5Ghz range, but I dont know why.- FURRYe38Dec 28, 2024Guru - Experienced User
Is Smart Connect enabled or disabled?
Try with Smart Connect disabled and devices connected on 5Ghz.
- PyroWolf89Dec 28, 2024Aspirant
Smart Connect is disabled, I've never had it on:
