PyroWolf89
Dec 21, 2024Aspirant
Inconsistent Speed Test with RS300 on WIFI, Good Hardline Speed, (Less then 20 feet dist.)
Router Firmware Version V1.0.1.60 So I have now been through 2 RS300's (which I bought for their 2 2.5GB ports, and am quite pleased with the performance of those ports), But I have this issu...
Dec 21, 2024Guru - Experienced User
What wireless devices are you speed testing with?
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
PyroWolf89
Dec 24, 2024Aspirant
Thank you for the reply.
I appreciate the through examples given, but I don't believe those principles apply here. I have tested the WIFI using my laptop (Intel AX201 Wi-Fi 6) and my Samsung S22+
My Laptop isnt 6E, so I cannot use the 6Ghz band, but my phone is.
The first chart is the laptop speed over the last 5 days, as you can see it varies rather dramatically. But I cannot find "why" it dips like it does, and it isn't device specific (2nd photo, phone, showing same dip of speed) but if I run the test with the 6E moments later I get 650 Mbps, same location.
I feel like its being throttled specifically in the 5Ghz range, but I dont know why.
- FURRYe38Dec 28, 2024Guru - Experienced User
Is Smart Connect enabled or disabled?
Try with Smart Connect disabled and devices connected on 5Ghz.
- PyroWolf89Dec 28, 2024Aspirant
Smart Connect is disabled, I've never had it on:
Does this happen as well with Smart Connect enabled?
- BH_CDec 28, 2024NETGEAR Expert
A few info needed to diagnose the issue:
- the internet speed subscribed
- what are the speeds when you run speed tests from the router (i.e. using the speed test function from the Nighthawk App)?
- I suppose the wired speeds are good?
- Even Smart Connect is disabled, use different SSID for different band, for example, use xxx-5G for the 5GHz WiFi only (different from the 2.4GHz and 6GHz) to check the speeds
- Are the speeds good at a close range (e.g. around 6 feet) but the speeds become unstable or slow when the range is longer?
- 2.5 GB
- 2300+ Mbps on Nighthawk app (See screenshot)
- 2300+ Mbps over CAT8 through the RS300 (See screenshot)
- I use 2G at the end of my 2.4, and 5G at the end of my 5. Example: WIFI2G and WIFI5G
- The slow speed on the 5 Ghz channel is consistent through the house, all get 150-250, when its "better" I can get anywhere from 500-800.
