Jun 11, 2024Guru - Experienced User
Introducing Nighthawk RS300 WiFi 7 (BE) Router
Nighthawk WiFi 7 Router, 9.3Gbps, 2.5Gig Port
The Nighthawk RS300 Tri-band router introduces blazing-fast WiFi 7 for speeds up to 9.3Gbps to budget-conscious but high-tech and gadget users.
- Blazing-fast WiFi 7 speeds up to 9.3Gbps for gaming, smooth streaming, video conferencing, and entertainment
- WiFi 7 delivers 2.4x faster speeds than WiFi 6 to maximize performance across all devices
- Sleek new body with smaller footprint and high-performance antennas for up to 2,500 sq. ft. of WiFi coverage
- 2.5 Gig internet port enables multi-gig speeds with the latest cable or fiber internet service plans
- 2x 2.5 Gig and 2x 1 Gig LAN ports for fast wired connections
- NETGEAR® routers are secure out of the box and built to stay that way with automatic firmware updates and industry-leading safety features to help protect you and your family
- NETGEAR Armor™ provides an automatic shield of security for your WiFi. Get real-time protection against hackers and added privacy with VPN. 30-day trial included1
- Compatible with any internet service provider
Availability
The NETGEAR Nighthawk RS300® is available now on NETGEAR.com and at other major retailers subsequently.
RS300: Router – $329.99 MSRP
Read more in the Nighthawk RS300 Series press release
1 Reply
Support Site:
