Intoxicating
Jan 11, 2024Star
IPv6 DHCP
Hi, Enabled IPv6 DHCP, the router gets the WAN allocation and devices get IPv6 addresses but no IPv6 traffic passes through. I’ve also noticed that even when using custom IPv6 DNS that the ...
Intoxicating
Jan 11, 2024Star
microchip8 wrote:
How do you know no IPv6 traffic passes through?
Because no IPv6 is detected when running a IPv6 test https://test-ipv6.com and can’t connect to IPv6 only sites yet when the Orbi is connected the IPv6 test and IPv6 only sites work.
Thanks
Jan 11, 2024Guru - Experienced User
If you can enable debug logging on the RBR and collect them before enabling IPv6 and DCHP there, then go thru the motions of checking IPv6 testing then after testing, save off the debug logs and get them to NG. Would be helpful for NG to review these logs. Post this up on a cloud service then send a share link to NG:
- IntoxicatingJan 11, 2024Star
- FURRYe38Jan 11, 2024Guru - Experienced User
Awesome. Hopefully that will help NG get a fix in place.
Thank you for your time.
