DragonUSA
Oct 21, 2025Aspirant
IPv6 is not supported in RS300
After many hours of support calls I was told IPv6 is only supported on the WAN side of the router, and not on the LAN side. Despite showing ICMPv6 makes it through to my end device on the wired LAN p...
CrimpOn
Oct 21, 2025Guru - Experienced User
It might be helpful to understand the goal. i.e. what you are trying to do.
