DragonUSA
Oct 21, 2025Aspirant
IPv6 is not supported in RS300
After many hours of support calls I was told IPv6 is only supported on the WAN side of the router, and not on the LAN side. Despite showing ICMPv6 makes it through to my end device on the wired LAN p...
Oct 21, 2025Guru - Experienced User
ALL NG routers support IPv6 WAN AND LAN side. Been like this for years.
Check and see if protection engine feature is seen on the RS web page please.
DragonUSA wrote:After many hours of support calls I was told IPv6 is only supported on the WAN side of the router, and not on the LAN side. Despite showing ICMPv6 makes it through to my end device on the wired LAN port, the RS300 blocks all IPv6 packets to any local UDP/TCP port. I believe the real story is that it is meant to work with IPv6 filtering set to open (as opposed to secure), but there is a bug in the firmware preventing proper operation. Rather than fixing the defect, they just state it is not supported on this residential grade router. This is not clearly stated in the product documentation prior to purchase.
- DragonUSAOct 21, 2025Aspirant
V1.0.5.18
EN2251The protection engine is off
- FURRYe38Oct 21, 2025Guru - Experienced User
And you did confirm having IPv6 with a PC directly connected to the ISP modem with out the RS router?
Testing at the IPv6 testing site:
What PC OS platform are you using?
Which ISP are you connected with?
IPv6 confirmed at the modem.
Various OS. Win 11 and FreeBSD.
Spectrum.
