Olive10
Oct 09, 2025Aspirant
Is it possible to disable Ipv6?
The user manual of the RS100 only gives different IPv6 connection types to choose from, but does not mention any option to disable it. Is it also possible to completely disable ipv6, both on the ...
Oct 09, 2025Guru - Experienced User
Olive10 wrote:Is it also possible to completely disable ipv6, both on the LAN side and on the WAN side?
I don't own the RS100, but Orbi routers do have a "disable" option in addition to the ones listed in the manual.
If you already own the router, then look for that choice.
