zeropointseven
Jun 01, 2025Tutor
Is there beta firmware for the RS90
Hi, is there beta firmware for the RS90 ? I just upgraded to this router. I am on FiOS 1 Gbps symmetrical down / up and am getting consistent 7-900 Mbps down but seem to be capping at 30 Mbps up. Did...
- Jun 02, 2025
Hi zeropointseven​, I just PM you the link to the trial firmware which shoould have addressed the issue. Please let me know if that works for you. Thanks.
Jun 02, 2025Guru - Experienced User
What is the brand and model# of the ISP modem or ONT that the router is connected too?
How are you speed testing? Using the onboard speed test or on a ethernet connected PC?
Be sure that Armor, Access Controls, SPC or Traffic Meter is disabled prior to speed testing.
