zeropointseven
Jun 01, 2025Tutor
Is there beta firmware for the RS90
Hi, is there beta firmware for the RS90 ? I just upgraded to this router. I am on FiOS 1 Gbps symmetrical down / up and am getting consistent 7-900 Mbps down but seem to be capping at 30 Mbps up. Did...
- Jun 02, 2025
Hi zeropointseven, I just PM you the link to the trial firmware which shoould have addressed the issue. Please let me know if that works for you. Thanks.
zeropointseven
Jun 03, 2025Tutor
Thanks so much for the prompt look and turnaround providing the trial firmware. It worked a charm and am getting symmetrical down / up speeds on my connection now.
Cheers !
Jun 03, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- zeropointsevenJun 03, 2025Tutor
Thanks for the recommendation, I've saved a backup as well :) Cheers
- FURRYe38Jun 03, 2025Guru - Experienced User
