zeropointseven
Jun 01, 2025Tutor
Is there beta firmware for the RS90
Hi, is there beta firmware for the RS90 ? I just upgraded to this router. I am on FiOS 1 Gbps symmetrical down / up and am getting consistent 7-900 Mbps down but seem to be capping at 30 Mbps up. Did...
- Jun 02, 2025
Hi zeropointseven​, I just PM you the link to the trial firmware which shoould have addressed the issue. Please let me know if that works for you. Thanks.
Jun 03, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
zeropointseven
Jun 03, 2025Tutor
Thanks for the recommendation, I've saved a backup as well :) Cheers
- FURRYe38Jun 03, 2025Guru - Experienced User
