Ski123
Aug 30, 2024Aspirant
LAN Connection takes a long time
I have two Netgear Nighthawk rs700's, one as the main router and one as the Access Point upstairs at the other end of the house. Yes it is in AP Mode and they are connected via ethernet for better b...
- Sep 03, 2024Yes, I did a bunch of testing and ultimately just cut a new cat6a cable and everything came back up with no issues. From main router 10G LAN to AP WAN. Something must have been wrong with that cable. Idk what could have happened to it. It’s looks just fine but obviously has a short or something wrong with it. I did set the static ip for the Ap but that’s just more so I can find it and sign in.
Aug 30, 2024Guru - Experienced User
What FW version is loaded on the RS's?
What CAT# LAN cable are you using? CAT6A STP is recommended.
How is the RS in AP mode configured? Using Dynamic or Static IP address configuration?
Is Access Control or Armor enabled on the host RS in router mode?
Does the RS in AP mode work better if you connect it's WAN port to the bottom LAN Port on the host RS in router mode?
Does same problem happen if you bring the 2nd RS to same room as 1st RS in router mode to test?
Ski123
V1.0.7.86_2.0.82 on both.
CAT6A STP is what I ran, checked with different cable just to make sure but problem persists.
set to dynamic
no Access Control or armor on either.
No, Just tested it. I moved from the top LAN port down to Port 1 and then reset everything and I still get the same issue.
Yes, I have tried many different cables as well.
- Ski123Aug 30, 2024Aspirant
SOLUTION FOUND!
special thanks to James Cornwatt who messaged me. I was running from the Main 10G Lan port to my AP WAN port but he suggested I run it to the 10G LAN port on my AP and everything started working immediately!
- ShadowMario3Aug 30, 2024Luminary
Great to hear that you found a solution! Is it safe to assume in both instances, you have the Cat6 cable connected from the main RS700's 10g LAN port to the second RS700's 10g Internet port?
Oddly enough, I never had this issue (I also have two RS700s with the second in AP mode with a 10gig backhaul connected to its Internet port), but I believe that might be due to me having two MS510TXUP switches between them instead of directly having a Cat 6 cable between the two of RS700s.
- FURRYe38Aug 30, 2024Guru - Experienced User
I presume the WAN port on the 2nd RS should work while in AP mode. Maybe something is not right there.
Might ask NG support about this as well or if the LAN port should be used for AP mode.
Well maybe I spoke to soon... It is working but I am now unable to sign into the AP. I ended up rebooting everything just to start fresh and then started testing the WAN port on the AP and now that works reliably. However the new issue, which I am going to make a new thread for, on my main router, I see the AP listed under the "Attached Devices" tab as a wired connection and is listed as a Netgear Satellite. When I sign out of the main and go to sign into the AP it tells me its disabled and that I need to enter the serial number and reset the password, I do that but its a loop. As soon as I reset it and click to sign in, it takes me back to the page telling me it is disable and I need to enter serial number.
