Bing1998
Jun 11, 2025Aspirant
Lan Led light on.
I just installed my Netgear rs100. the ethernet and wireless are working as they should. I have 8 devices on wireless connections that are working fine. Why is the LAN LED light illuminated. It i...
Jun 11, 2025Guru - Experienced User
Are you referring to the WAN port LED or the LAN port LED? Which port LED is on and what color is it?
Check the user manual for LED status and color meanings.
What brand and model# is the ISP modem?
