Bing1998
Jun 11, 2025Aspirant
Lan Led light on.
I just installed my Netgear rs100. the ethernet and wireless are working as they should. I have 8 devices on wireless connections that are working fine. Why is the LAN LED light illuminated. It i...
Bing1998
The Lan port Led is on and color is red, indicating a problem somewhere. My wireless network has a good connection to eight different items.
- FURRYe38Jun 11, 2025Guru - Experienced User
What is connected to the LAN port?
- michaelkenwardJun 11, 2025Guru - Experienced User
You would not be the first person to see that as a RED LED. It may well be AMBER.
When that happens, the router is usually telling you that something "slow" is plugged into that port. A lot of devices work happily at 100 Mbps. The usual suspects in such cases are TVs and media players.
