Bing1998
Jun 11, 2025Aspirant
Lan Led light on.
I just installed my Netgear rs100. the ethernet and wireless are working as they should. I have 8 devices on wireless connections that are working fine. Why is the LAN LED light illuminated. It i...
Jun 11, 2025Guru - Experienced User
What is connected to the LAN port?
Bing1998
One 4k sony Tv and one Arlo security camera base station. that is it. on gamers here.
- FURRYe38Jun 11, 2025Guru - Experienced User
And is any of these connected to the LAN port?
Can you take a screen shot of the front of the RS and post it here?
- michaelkenwardJun 11, 2025Guru - Experienced User
That will connect at 1GBps. Mine do.
Bing1998 wrote:
4k sony Tv
Could well connect at 100 Mbps.
Just another user with time on their hands.
