ggallant571
Apr 28, 2025Aspirant
local device name service
I have installed a Nighthawk NF70 router on my home network. Each local device is getting a proper IP and is able to connect with the internet. What is not working is the local name service. I can us...
michaelkenward
Apr 29, 2025Guru - Experienced User
Look at the label for the Netgear Model Number.
Model number label
- plemansApr 30, 2025Guru - Experienced User
RS70 is a lowend BE3100 device. Could be what they have.
- FURRYe38Apr 30, 2025Guru - Experienced User
Interesting. Seems that NG is milking the RS model line for sure:
https://www.netgear.com/support/product/rs70/
Thought they would have had enough RS models to select from. Guess this will be low budget for sure.
