mercurycc
Oct 05, 2024Aspirant
Losing internet connection every 80 minutes
Last couple of days I noticed my teams meetings / online games will disconnect every once in a while. Today I finally looked at my router log, it seems internet is lost every 80 minutes, each time fo...
mercurycc
Oct 06, 2024Aspirant
Could be yes, but last night I decided to reset only the router and left the modem running (modem is Comcast Gateway), and the issue is gone.
Oct 06, 2024Guru - Experienced User
Does the front Internet LED on the RS turn AMBER or RED when this happens? If it does, means the RS is not getting a good signal from the ISP Modem or Gateway.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
Good Luck.
- mercuryccOct 06, 2024AspirantNow that the problem is gone I can't check it anymore. But the modem is already in bridge mode. Regardless, I can't imagine what kind of issue will cause precise internet disconnect every 80 minutes, almost to the second.
- FURRYe38Oct 06, 2024Guru - Experienced User
Ya thats a odd one for sure. Glad the factory reset seemed to help. Wondering if some odd issue got the modem or router or both in some bad state.
Enjoy. 📡- mercuryccOct 06, 2024AspirantOh sorry, was mixing up terms... I just unplugged power and plugged it back in, and that got rid of the problem. Wasn't a factory reset.
So something in the firmware state could be corrupted. Maybe.
