thomasknight
Oct 25, 2024Aspirant
MAC Address Issue
I set up my new Netgear router today. I had significant trouble establishing an Internet connection. I was previously using a Spectrum router. I was trying to install the new Netgear router to use wi...
- Oct 25, 2024
Thank you! I ended up doing a factory reset of the ISP modem and that worked.
thomasknight
Oct 26, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
