Gjl1950
Feb 08, 2026Aspirant
media server not connection to wired connection
r300 router sees hard drive, my samsung s90d connections to media server when connected wirelessly, but when I connect my samsung s90d tv to a wired connection the media server does not show on t...
Feb 09, 2026Guru - Experienced User
Might just try connecting the hard drive to the tv. Then you don't have to worry about transmitting the data.
- StephenBFeb 10, 2026Guru - Experienced User
Worth testing. But whether that is a useful solution depends on where else you might want to play the media.
Gjl1950 hasn't responded since the initial post, so it's not clear if this is still a concern or not.
