Gjl1950
Feb 08, 2026Aspirant
media server not connection to wired connection
r300 router sees hard drive, my samsung s90d connections to media server when connected wirelessly, but when I connect my samsung s90d tv to a wired connection the media server does not show on t...
Feb 11, 2026Guru - Experienced User
The "media server" built into routers is pretty anemic. The only half-decent one was on the R9000 with built-in Plex.
I'd try the one on the tv. If it doesn't work with the built-in hard drive, I'd check into picking up something with built-in or optional transcoding. Plus then it'd stream to your other devices decently.
A cheap N150 pc would do it that you could install plex of jellyfin to. Or even a nvidia shield with plex built in would be a great upgrade. Or even an old pc sitting around
- StephenBFeb 11, 2026Guru - Experienced User
Something is wrong if it works on wifi but not ethernet.
Personally I use Plex running on a PC myself, but the DLNA server in the router is ok if you don't need transcoding.
That's not a media server - if Gjl1950 uses it, then that TV is the only device that can play the content.
