Gjl1950
Feb 08, 2026Aspirant
media server not connection to wired connection
r300 router sees hard drive, my samsung s90d connections to media server when connected wirelessly, but when I connect my samsung s90d tv to a wired connection the media server does not show on t...
Feb 12, 2026Guru - Experienced User
StephenB Even when the OP replied, they didn't add any information to their original post. Tough to help without accurate replies.
- StephenBFeb 12, 2026Guru - Experienced User
Actually they confirmed that they are using the media server in the router, and not something else. And that the ethernet is connected to a router LAN port.
Well, I think the place to start is to double-check that the ethernet connection itself is working correctly.
