tvarsano
Dec 28, 2023Initiate
MLO (Multi Link Operation) WiFi7 of RS700
Hi, Does RS700 with V1.0.7.82_2.0.80 support MLO (Multi Link Operation) WiFi7 capability? How should I configure it?
Dec 28, 2023Guru - Experienced User
Does the spec sheet say thing about MLO?
Possible that NG maybe still in development on this as wel.
- tvarsanoDec 28, 2023Initiate
According to the technical Specification sheet (https://www.netgear.com/home/wifi/routers/rs700s/)
Multi-Link Operation1—Uses multiple WiFi bands at once to improve network reliability, reduce latency, and ensure data is delivered with maximum speed. Scheduled to be released by Q4 2023.
- FURRYe38Dec 28, 2023Guru - Experienced User
Well, may and ran into development issues or still in testing on it.
I'm now the Orbi 970 system has it enabled however is only for the satellite backhaul. Nothing front user facing yet. And also there isn't any MLO supporting user devices as well. I can only presume MLO is still under development and probably won't see anything until the new year hits. Can only speculate though.
- BH_CDec 28, 2023NETGEAR Expert
MLO is not supported on the RS700 yet. We still work on the firmware release for the MLO support.
