tvarsano
Dec 28, 2023Initiate
MLO (Multi Link Operation) WiFi7 of RS700
Hi, Does RS700 with V1.0.7.82_2.0.80 support MLO (Multi Link Operation) WiFi7 capability? How should I configure it?
Dec 28, 2023Guru - Experienced User
Does the spec sheet say thing about MLO?
Possible that NG maybe still in development on this as wel.
tvarsano
According to the technical Specification sheet (https://www.netgear.com/home/wifi/routers/rs700s/)
Multi-Link Operation1—Uses multiple WiFi bands at once to improve network reliability, reduce latency, and ensure data is delivered with maximum speed. Scheduled to be released by Q4 2023.
