mavere
Feb 13, 2024Aspirant
My workaround was to set the RS700 in AP mode and connect it to the official Verizon router
If you can get it working well, please let us know.
My workaround was to set the RS700 in AP mode and connect it to the official Verizon router (with its wifi broadcast turned off). I wonder if...
Feb 13, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
If the Verizon unit has a built in router, disabling WiFi won't be enough.
Does the Verizon router have 2.5Gb LAN ports?
Also, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
