Blaze-2025
Jun 17, 2025Aspirant
Need Main 2.4G Network - Internet Access Only
I Would Like to Configure my Main 2.4G Network to be "Internet Access Only" just the same but without enabling a Guest Network "Specifically" to prevent them from competing with each other. I only...
- Jun 18, 2025
As Always - Will Figure Out On My Own...
michaelkenward
Jun 17, 2025Guru - Experienced User
Blaze-2025 wrote:I Would Like to Configure my Main 2.4G Network to be "Internet Access Only"
Not sure that I follow that.
Have you looked at the manual?
Start here and feed in the model number:
Nighthawk RS70 | WiFi 7 Router | NETGEAR Support
Check the section Manage WiFi Settings.
Just another user with time on their hands.
