Blaze-2025
Jun 17, 2025Aspirant
Need Main 2.4G Network - Internet Access Only
I Would Like to Configure my Main 2.4G Network to be "Internet Access Only" just the same but without enabling a Guest Network "Specifically" to prevent them from competing with each other. I only...
- Jun 18, 2025
As Always - Will Figure Out On My Own...
CrimpOn_old
Jun 17, 2025Star
There is no feature to restrict (or forbid) any part of the primary network in terms of access to the internet (devices that are 'wired' or connected to the primary 2.4G and 5G WiFi networks).
The only feature that does anything like this is the exact opposite (Block Services) which can restrict devices from internet access by IP address.
Blaze-2025 wrote:prevent them from competing with each other.
What does "them" refer to?
- Devices?
- WiFi management frames, such as beacon frames?
