Blaze-2025
Jun 17, 2025Aspirant
Need Main 2.4G Network - Internet Access Only
I Would Like to Configure my Main 2.4G Network to be "Internet Access Only" just the same but without enabling a Guest Network "Specifically" to prevent them from competing with each other. I only...
- Jun 18, 2025
As Always - Will Figure Out On My Own...
Jun 17, 2025Guru - Experienced User
If you disabled smart connect on the router and disabled the 5Ghz radio, and not enable Guest Network, you could have 2.4Ghz wifi only for internet access only on this radio. LAN ports are still accessible to the internet.
Blaze-2025 wrote:I Would Like to Configure my Main 2.4G Network to be "Internet Access Only" just the same but without enabling a Guest Network "Specifically" to prevent them from competing with each other.
I only need/want "One" active 2.4G network signal with Internet Access Only. Any help or suggestions would be greatly appreciated... Netgear Router RS70
