Blaze-2025
Jun 17, 2025Aspirant
Need Main 2.4G Network - Internet Access Only
I Would Like to Configure my Main 2.4G Network to be "Internet Access Only" just the same but without enabling a Guest Network "Specifically" to prevent them from competing with each other. I only...
- Jun 18, 2025
As Always - Will Figure Out On My Own...
Blaze-2025
My thoughts that came up with this question: Since I only needed a 2.4ghz WiFi Guest network setup for connecting ioT smart switches and friends and family aka guests that connect to that Wifi, it seemed strange to me that the "unused" 2.4ghz primary would be active for no reason except to enable the quest network feature. Guest Networks cannot work/enable without primary enabled.
michaelkenward
Jun 20, 2025Guru - Experienced User
Blaze-2025 wrote:I only needed a 2.4ghz WiFi Guest network setup for connecting ioT smart switches and friends and family aka guests that connect to that Wifi
This seems to be the "problem" that you are trying to solve.
There have been plenty of discussions around here about getting IoT things to work. They often boil down to badly written apps for the IoT device.
As the manuals explain, there are various ways of showing and hiding SSID broadcasts, and separating and joining SSIDs.
As to this:
Blaze-2025 wrote:"unused" 2.4ghz primary would be active for no reason
If it really is "unused" why not just forget about it? It won't be getting in the way of anything.
