Landyman's avatar
Landyman
Need to set-up an RS500 with a Modem
Hi, I am having a dry run in order to set-up the Modem to see if it works before I move cables and install my RS500. As part of the Modem install I have to fix the ip address of my PC to 192.168.1.1 ...
  • FURRYe38's avatar
    Yes. Should work.
