Landyman
Feb 10, 2025Aspirant
Need to set-up an RS500 with a Modem
Hi, I am having a dry run in order to set-up the Modem to see if it works before I move cables and install my RS500. As part of the Modem install I have to fix the ip address of my PC to 192.168.1.1 ...
- Feb 11, 2025
Yes. Should work.
Landyman
Feb 11, 2025Aspirant
Hi, Sorry if I am being thick but I'm not sure I understood you completely., Was your Yes that it can be used as a Modem Bridge and attached to the RS500 without problems? Can I proceed with it or do I need to buy another Modem?
