Netgear_junk1
May 20, 2025Aspirant
Netgear Horror Story
Short version...two Nighthawk 7 routers (BE9300s) since Saturday (3 days ago), have been basically bricked by Netgear's atrocious tech support. 10 hours in 2 days on the phone, on hold with the w...
May 20, 2025Guru - Experienced User
I'm not even going to try to argue with that. My impression of tier 1 support has always been pretty atrocious. So sorry you got that.
Maybe we can fix/help on here though
- what actual issue are you having?
- what's going on with the routers?
- what are the led's doing?
- what modem/gateway is the router connected to?
