Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
May 28, 2025Guru - Experienced User
So when you put the C series gateway into modem only mode, did you power OFF both modem and RS router for 1 minute then back ON then check to see if you get internet access services first here?
