Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
Blaze-2025
May 28, 2025Aspirant
Thanks for reply - But the no internet issue only occurs when in router mode with WiFi signals and DHCP server turned off. Modem/Bridge only gets internet but then I lose the USB Readyshare connection. I think it's something to do with basically connecting modem/router to router settings or how Cat5e cables are connected??
- FURRYe38May 28, 2025Guru - Experienced User
For the C series modem in modem only mode, the RS should have WIFI and DHCP services enabled. Modem only mode on the C series gateway disables wifi and router portion of the modem and just works as a modem. You'll need to power OFF both modem and RS router for 1 minute then back ON and the RS should be getting normal internet services here.
And you have the storage device connected to the RS router?
