Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
Blaze-2025
May 28, 2025Aspirant
You clearly are NOT understanding - Read the Original post slowly...
- FURRYe38May 28, 2025Guru - Experienced User
Yep, it's been read.
Maybe put the C series back in router mode and connect the storage device to the gateway, disable WiFI radios on the modem and configure AP mode on the RS router.
- Blaze-2025May 28, 2025Aspirant
RS70 Must be Primary Router
