Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
May 28, 2025Guru - Experienced User
Why does the RS70 have to be in router mode/act as primary?
You can use the C7000 in router mode with its full capabilities and the RS70 in access point mode. You can even leave the wifi enabled on the C7000 if you'd like. Just make sure its on different wifi channels and using a different ssid.
