Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
Blaze-2025
May 28, 2025Aspirant
This whole new equipment thing started because I wanted to introduce a Netgear LM1200 4G Modem as Backup/Failover which would not work with C7000v2 as modem/router combo.
That's where the New RS70 (No USB Readyshare) comes in and then I discovered the C7000v2 Readyshare gets deactivated in Modem Only Mode. Just trying to find a creative solution to regain access to my USB Drive short of buying RS200 that has a USB port for Readyshare. Or even a USB to ethernet dongle if there is such a thing? Thanks...
