Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
May 28, 2025Guru - Experienced User
I feel like you're trying really hard to get ready share to work.
so what you want.
- readyshare
- failover to the lm1200
sound right?
If so, I'd check into a router that supports dual wan with failover and a USB device. It won't be netgear as those are more business class requirements.
