Blaze-2025
May 27, 2025Aspirant
Netgear NH - RS70 (No USB ReadyShare)
Been using USB Readyshare on C7000v2 Modem/Router Combo since purchased a few years ago. Needed to add a new Separate Netgear RS70 router and it's clearly understood that USB Readyshare is deactivate...
Blaze-2025
May 28, 2025Aspirant
Thank You Everyone Offering Many Ideas - I will take into consideration. However, I feel all the devices I have should be able to talk to each other...
Will first try a few more things before throwing in the towel - Any other suggestions please let me know!!
Respectfully, Blaze
May 28, 2025Guru - Experienced User
If you have a USB drive that your trying to use for ReadyShare on a NG router while in router mode, then you'll need an RS router model that has the USB port in back for the USB drive to be connected to. The RS70 doesn't have a USB port. One of the RS models should have a USB port. My RS600 has USB port and I believe some of the other models do as well.
Checking, first model RS seen with a USB port is the RS200. I presume that model and up have USB ports.
