l1undy
May 02, 2024Aspirant
Netgear Nighthawk BE19000 WiFi 7 Router
My Netgear Nighthawk BE19000 Tri-Band WiFi Router (RS700S) arrived. I am upgrading from a Nighthawk AX6600. That router is moving from my living room to my guest bedroom in order to support my new Ub...
May 02, 2024Guru - Experienced User
Either height would be fine. I've tried a variety of heights and haven't really noticed much difference. the only time I usually see a difference is with things like appliances blocking the signals.
